Phobiac
Justin Meldal-Johnsen Gets REDDI with A Designs
NSGHT00020041220e0ck000ji
By Mix Editors
415 Words
20 December 2004
Primedia Insight
Online Exclusive - Mix
English
Copyright 2004 by Primedia Business Magazines & Media Inc. All rights reserved.
Session bassist, songwriter, and member of Virgin Records much-buzzed-about modern rock act Ima Robot, Justin Meldal-Johnsen has graced recordings by
artists such as Tori Amos, Courtney Love, Macy Gray, Garbage and Pete Yorn while simultaneously working with Beck as both his bassist and music
director. Needless to say, he’s learned a thing or two about direct boxes, and often leans toward A Designs’ REDDI.
"Since the bass guitar is my exclusive instrument, I'm always plugged into a DI," Meldal-Johnsen explains. "I've used so
many. Generally the thing that I hate about DIs is that when you plug a bass into them, the sound seems to be useful to engineers, but it's often
distasteful to my own ears. Most DIs have a glassy, transparent, sort of weightless sound with a lot of top end—unnatural and clinical. If
you're lucky, one might have sub-harmonic content, but even then it will probably have a glassy-sounding fundamental tone. Too many engineers
seem to be resigned to the fact that using these are good ways to get bass sounds—just blend it with an amp, and you're golden. I just
don't think that's enough. The DI alone should sound amazing."
Meldal-Johnsen solely used the REDDI during recent sessions for the soundtrack of an upcoming feature thriller scored by Tyler Bates, composer for
Dawn of the Dead. "I didn't use an amp at all," says Meldal-Johnsen. "I used only the REDDI and it sounded really, really
nice."
The fire-engine red REDDI tube DI is designed for use with basses, guitars, synthesizers and other electronic instruments. The REDDI features a 6N1P
tube, Neutrik combination XLR/quarter-inch input, balanced XLR output, on/off toggle switch, LED power indicator, level control knob, ground lift, EIN
power connector, a metal vented casing, custom output transformer and an enclosed power supply with Toroid power transformer. The REDDI can also be
rack-mounted for use with two or more units.
Regarding his work with Ima Robot, Meldal-Johnsen says that his sound “generally needs a little grind to it, so I'm going to use the REDDI with
an Ampeg B15 for a clean amp sound, a Marshall JTM-45 head and Fender ToneMaster 2X12 cabinet for a dirty amp sound, and the REDDI. That's the
signal chain.”
For more information, visit www.adesignsaudio.com .
[Edited on 12-20-2004 by draconian]
I totally understand everything he's talking about...
seacaptain
Lyrical Gangster
Mood: odelay
JMJ is such a geek
draconian
Quote: | Originally posted by seacaptain
JMJ is such a geek |
Yeah, it's like, why don't you join the AV club already, Justin?
batcave_baby
Big Radiator
Mood: No Mood.
What? I thought he was talking about wine.
